跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4099 个问题 查看全部
Tried to replace battery, ripped glass screen off front panel
Not really sure what to do from here. Followed the battery replacement guide, instead of pulling up the whole front panel, the suction cup ripped the actual screen off the front panel. Phone still works, just screen isn't secure. Do I glue the screen back onto the phone with super glue and then try again? Google returns nothing for a problem like this, so it must be a rare occurrence. Any help is greatly appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
已选择的解决方案
Unibond is a very good glue I've used to secure loose frames in the past, extremely strong and very easy to work with.
I used to use the iSlack on the 5S, but don't do it anymore, especially if the screen has been replaced before, because if the glass pops out and pulls the home button with it, then no more Touch ID, using something like a iSesamo tool is perfect and a lot safer to remove screens.
这个答案有帮助吗?
得分 1
添加一条评论
I usually use epoxy when this happens, super glue should work too. Remove the front housing by prying up the frame, be weary of the cables. then remove all the parts attached to the screen (camera, speaker etc..) and do the sticky work. Give it some time to dry.
这个答案有帮助吗?
得分 0
添加一条评论
super glue will work but is far less than ideal. Over time super glue does not stay bonded to glass well. The loctite gel super glue is a favorite of people that do this often, it stays where you put it better and gives you a little bit of working time before it cures. Don't let super glue (or whatever glue you use) get on the backlight or the edges of the lcd.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rtja 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 96
