跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
82 个问题 查看全部
Black Screen, No Boot, LCD is on but nobody's home.
Hi.
I've recently replaced the screen on my Z3 Compact (I've done this a few times before...) but I think this time I've definitely done something wrong.
Symptoms are as follows:
Phone is on, LCD is working (I can only tell this from the backlight being on) but nothing will boot up. I turn the phone on and I don't get a splash screen or boot up noise.
I've tried resetting it using the power button/volume switch but still get nothing
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
最有帮助的答案
I had this issue on Sony Xperia Z Ultra once and it was because a component was knocked off. Sometimes when you pry to get the connector off you can also knock off a component. On the picture I have circled the components that if damaged or knocked off would give "No Image" and symptoms similar to what you describe. I would check all the other components around the connector as well and see if you can see any damage.
It could also be a faulty screen. If you try another screen that you know is working obviously that would eliminate it as the problem.
这个答案有帮助吗?
得分 2
4条评论:
Thanks - I'll take a look when I get home.
完成的
Does this image apply to xperia Z3?
完成的
What are these components and what do I do when there is one missing? How can I get a new one?
完成的
He miss one component like that on my Z3 and i got no image but a white or black screen. What can i do?
完成的
添加一条评论
Hi, I have the same problem with a Z1 compact. The broken screen DOES light up, the new screen shows ONLY backlight.
When I try the new screen on a DIFFERENT Z1 compact, it DOES work.
So it looks like this particular Z1 does not want to work with this new screen.
But what can be the reason? The broken screen works (at least, lights up and shows image), the new one does not. (on this device)
这个答案有帮助吗?
得分 0
2条评论:
You may need to try a new screen, I have had issues with different displays. Some displays have different versions.
完成的
I have the same problem with z3. I have removed the screen and attached it again with adhesives as it was coming off. The phone seems to be functional but only the screen does not work. (black background only)
完成的
添加一条评论
i have a Z1 with the same problem, cant seem to find a solution
这个答案有帮助吗?
得分 0
添加一条评论
Same here, but what are these component, resistance that we maybe can jump or another like capacitor ?
这个答案有帮助吗?
得分 0
添加一条评论
The black screen problem may caused by your z3 compact drop or suffer collided, which makes the flex cable loosen. you can try to disassemble your phone and reconnect the flex cable.
However, if flex cable reconnect can not fix the screen problem, then you should turn to the hardware solution: change a new screen. We provide the original lcd screen for Sony xperia z3 compact. and we provide the repair guide and fix tools to help you replace.
这个答案有帮助吗?
得分 0
添加一条评论
Try pressing your Speakers output, both of them, hard. It is problaby loose because of moisture and heat during severe conditions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matt wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 5,114
