跳转到主内容
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
125 个问题 查看全部
What caddy/adapter is needed to install an SSD?
What caddy/adapter is needed to install an SSD into the hard drive bay?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
Follow this IFIXIT guide iMac Intel 20" EMC 2266 Hard Drive Replacement. Make sure you peel off the thermal sensor from the HD as you'll need to put it on the SSD.
As for the needed hardware all you'll need here is a 2.5 to 3.5" drive adapter frame.
The other option here is to swap out your optical drive for the SSD. Here you'll need an special adapter. Here's the IFIXIT guide if you decide to go this way: Installing iMac Intel 20" EMC 2266 Dual Hard Drive.
iMac Intel 20" EMC 2266 硬盘图片
指南
iMac Intel 20" EMC 2266更换硬盘指南
难度:
中等
45 minutes
iMac Intel 20" EMC 2266 Dual Drive图片
指南
Installing iMac Intel 20" EMC 2266 Dual Drive
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
http://www.ebay.com/itm/iFixit-iMac-Inte...
this si the type of install kit you may use, i did this and it was the only option without removing any hardware from the imac
这个答案有帮助吗?
得分 0
评论:
As the OP is replacing the HD with the SSD this kit won't offer any benefit as he will be reusing the drive cables in the system.
完成的
添加一条评论
添加你的答案
applerepairshop 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 659
