跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4098 个问题 查看全部
Caller can't hear me iPhone 5s 16GB Gold
When I make or receive a call, person on other end can't hear me unless I put phone on speaker?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
Hi pinkcat1972,
I would start by taking a sewing needle and some air duster and try cleaning out the set of 10 small holes next to the audio jack. If this doesn't work. I would recommend opening the phone and checking to see if the dock flex connector is properly seated. It is located towards the bottom right side of the battery, above the battery connector. Use an iPhone 5s disassembly guide here on ifixit. No need to disconnect the LCD or anything. If you find it is connected and is still not working, you are most likely gonna need a dock flex cable. It's a very simple installation. I'll link the part you need and the guide for it.
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Lightning连接口更换
iPhone 5s Lightning Connector and Headphone Jack图片
产品
$24.99
这个答案有帮助吗?
得分 0
添加一条评论
Josh's answer is excellent; there's an even simpler failure that sometimes happens. Try putting in headphones and pulling them out again. Sometimes dust etc. gets wedged in the contacts of the headphone jack and causes the phone not to go back into the 'handset mode.' Putting headphones in a time or two will sometimes fix this, and it's a useful diagnostic in any case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pinkcat1972 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 116
