跳转到主内容
Product released in 2011. Portable on-ear headphones that come with a detachable audio cable with built-in remote and mic for iPhone/iPod/iPad connections, and a carrying case.
22 个问题 查看全部
One side of the headphones aren't working
How do I fix the headphones so both sides are working?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
Cole Nagashima, you need to check a few things. start with the audio cable. Use a multimeter to check for continuity. Should the cable be okay, check the audio jack to make sure that all the wires are still soldered to it. If that checks out ok, check the wiring continuity from the audio jack to the non-functioning driver (speaker). The repair will depend on what needs to be fixed.
这个答案有帮助吗?
得分 3
添加一条评论
Just check the cable with a resistor meter. if everything works out take out the side of the earphone that doesn't work. decoder the earphone and replace it
这个答案有帮助吗?
得分 1
添加一条评论
I checked the wires going out from where they split at the 3.5mm female jack.
The left side is good, but 1 of the two cables going the the right side isnt receiving any current.
What should I do?
这个答案有帮助吗?
得分 0
1条评论:
Eeem... guys? How do you fix both parts?
完成的
添加一条评论
添加你的答案
Cole Nagashima 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 15,135
