跳转到主内容
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33 个问题 查看全部
Replaced lcd screen and phone turns on with black screen Please help
I definitely was very careful yesterday, I even took it apart first and put it back together and it worked all day, got the new screen from different phone and does not seem to work, i took it apart 3 times already to check connections, everything seems to be ok, except the screen it shows all black, no sound etc.
Please need some help, is the screen programed with the motherboard ? Any other possible problems ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
How do you know the LCD screen you replaced it with was good? Have you tried putting the old one back in? Why did you change it if it was working?
完成的
添加一条评论
1个答案
最有帮助的答案
ok, what happens when you reconnect the old screen??
did you only replace the lcd or the cable too?
since you mentioned that there is no sound and nothing on the screen.
so most likely the problem is not the lcd - but the cable where it' connected to!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
isra c 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,484
