跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
243 个问题 查看全部
Why does my Xbox 360 go from green light to solid red?
When I start Xbox 360 S, the light goes green for a few seconds and then goes to a red dot in the center. I replaced the power cord, still get the same result. I removed and replaced the hard drive, still the same. I replaced the hard drive with a new one, still the same. What could be the problem and how do I fix it?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 4
添加一条评论
2个回答
已选择的解决方案
HogsTooth13, seems to be the RDOD (Red Dot of Death;-)Since it is most like not under warranty anymore, check the optical drive. Apparently it can cause the RDOD. Also check Youtube for some decent explanations. This video shows one more trick you can try. If none of that works, open your console and clean the airvents properly of all collected dust and debris, change the thermal paste and try, or consider some heat to the flip chip (very temporary fix). Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 4
评论:
Thanks, oldturkey03 I'll give it a go and hope for the best.
添加一条评论
Sell it for parts on ebay for $50.00 & buy another one !!! Nuff said !!!
Update (10/22/2018)
The way the trinity sets are designed they are hard as snot to take apart & pry the sides off without breaking the tabs, putting on new thermal paste & heat is just a temporary fix & you will get the RROD Red Ring Of Death again !!! Sell & get a another one !!!
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
HogsTooth13 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 41
过去的30天: 209
总计 13,774
