跳转到主内容
修复你的物品
维修的权力
配件 & 工具
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
400 个问题 查看全部
Home Button Not Working
I'm having a problem with the home button on a 32gb iPod Touch 5. When the home button is pressed, nothing happens. However, if I pull the screen up and press the home button flex cable dome, it responds normally. I've tried replacing the plastic home button and rubber gasket, first transferring the original metal contact disc, cleaning the metal contact disc and home button dome with denatured alcohol and I made sure that the LCD assembly is seated back into the frame properly, etc., but nothing is working. What could be wrong? Can someone out there help me figure this out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Did you ever find a solution to this? I'm having the same issue. It almost seems like there needs to be a piece protruding from the (interior) home button that contacts the metal plate on the (exterior) home button.
完成的
Hmmm, any insight on this, my iPod seem to be the same, the internal button work if i use a point to poke it but it does not when i press from the home button itself...seem like a small piece is missing between the home button and the switch's middle.
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
2个回答
There is a setting in settings that has a popup on the screen were you can go home
这个答案有帮助吗?
得分 0
添加一条评论
I had this same problem. There's a small black dot (very small, very easy to lose) that sticks up on the home button, and is what pushes down the button on the flex cable. I cut a small piece of VERY thin plastic and super-glued it to the top of the flex cable button, and it works like a champ. Like William said, though, you can use the assistive touch under settings/general/accessibility to turn on a virtual home button and place it wherever you want it on your screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AZMICROREPAIR 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 4
总计 609
