跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How to find out if my cellular antenna is damaged for sure?
I have this "searching..." error and tried everything already..! The only possible fix is to replace the cellular antenna, since I dropped the phone a lot of times and I heard that this could cause my problem too. However, is there any way to check if the antenna is really damaged or broke before I go and waste my money for nothing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Just a suggestion but sometimes its not the antenna but the SIM card from the carrier that has gotten dislodged or messed up somehow, maybe a droplet or water perfectly landed on the door to it, or whatever, might check that first since it the easiest then, if your cell carrier doesn't use SIM cards then disregard this message
这个答案有帮助吗?
得分 0
1条评论:
thanks for your answer! I checked that too... with a second (and 100% functioning) SIM-card but it didn't solve the problem... But once I did a hard reset and I got signal for 10 minutes but then it went back to "searching..." again..! :/
完成的
添加一条评论
Adam Kustrio - I have an iPhone SE. It fell off a counter I have that might be 3 foot high. After that, I wasn't able to call out or receive calls. I took it to the T-Mobile store, they exchanged the SIM card, and that didn't work. (Same situation) - they suggested calling the claim number to report the antenna is messed up, and to ask for an exchange (since my phone isn't paid off yet). I shall see!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam Kustrio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 65
总计 15,758
