跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Replacing failing hard drive
The hard drive in my mid 2011 27",iMac is failing. My question is the following: I fixit sales install kits for adding an additional drive --SSD or otherwise. Is it reccomended that you keep the old failing drive installed after installing the replacement/additional drive? I ask because, I have not seen a kit for solely replacing the drive, only for adding another.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Here's the guide for replacing the drive: iMac英特尔27“EMC 2429硬盘更换
If you have another Mac, put this machine into Target Mode and see if it can be repaired using Disk Utilities, and transfer your files if they can be accessed till the new drive is installed. If not let us know as the new drive will need to be formatted and a system installed, then using either an external enclosure or a Universal adapter such as this: http://eshop.macsales.com/item/Newer%20T...
transfer your data if it is accessible.
这个答案有帮助吗?
得分 3
添加一条评论
You don't need a kit for replacing the drive, all the hardware is already in place though you will have to move all your data to the new one. I would not recommend keeping a failing drive in your system.
这个答案有帮助吗?
得分 1
添加一条评论
A failing drive may trigger the HDD fan because it may warm up, and the result would be pushing your HDD fan to its max rotation (around 6000 rpm) and this may not be a pleasant experience, therefore it is advised to remove or replace that drive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
K Warren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 594
