跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
问题已关闭
My GPS & Wifi signal are very low after water drop
Hello there,
I drop a bottle of water on my oneplus one, since then, my gps can't fix and my wifi only find network if i'm less than 1meter of the router.
I tear it down, clean everything, but still no luck, do you think the antenna in the backcase may be the problem?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello
Mobile'll swim the basic power is no major damage
Note that one plus phones GPS & WIFI antenna is in the back cover, based on your description I think it is the back cover of the antenna appears oxidation or corrosion, you can try to use alcohol / eraser to clean; of course, do not forget to clean up PCB on contacts: )
I have a another idea is that you can replace a cover, just to change a set of wood or other materials ~
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 311
