跳转到主内容
Repair guides and support for your Samsung TV.
2612 个问题 查看全部
Computer won't mirror onto my Samsung 50" plasma TV.
I have a Samsung 50" plasma that's all I know it is called. I have brought a desktop in hope to mirror it onto the TV. The computer is registering that my TV is connected but the TV just says no signal. I have tried several hdmi cables. At one point the TV did work for a split second but now won't. Does anyone have an answer to why this is. I have also tried in all three hdmi connections on the TV.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What desktop do you have? Are you using onboard graphics or does the PC have a graphics card added. Do you know if the PC is using the correct driver for your graphics? If it isn't then that may be why your HDMI isn't working. If you need help with a driver then let us know the model of desktop you have as well as what operating system it is running. If you have an added graphics card let us know what model it is too.
完成的
添加一条评论
1个答案
已选择的解决方案
On your tv there will be a place for source probably on your remote this needs to be set to your input which will be labeled on the back of the tv were you plug in your hdmi. Match up your input to you source and there should be a picture
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Perrie Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 526
