跳转到主内容
Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 个问题 查看全部
Why won't my iPad turn on?
I've tried everything suggested to turn on my iPad 4; however, nothing works. Apple Store said it's not the battery but internal . How do I know what to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Has the iPad ever been worked on before?
Has it recently suffered any falls or water damage?
Unless they disassembled it at the apple store and tested the battery, they wouldn't know whether it's the battery or something else. The first step on this repair would be to clean the charge port very well, then try charging it. Try a new cord and power brick if that doesn't work. Also see if iTunes recognizes it, the device could be in DFU mode. If those fail, then you will need to open the iPad and test the battery with a multimeter. You will want to ensure that it is producing the voltage written on the battery, or slightly more. Also ensure the charge port is plugged in. I'm sure you will find your issue by this point, I've never seen an iPad board just go bad out of the blue like that.
这个答案有帮助吗?
得分 2
2条评论:
I wish I understood your technical terminology!
完成的
I will try all! Thank you!
完成的
添加一条评论
添加你的答案
Paula Sandoval 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 159
