跳转到主内容
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
47 个问题 查看全部
tv is on but flashes on and off, doesnt take any input
on and off screen, no input taken
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
6条评论:
How many times does the screen turn on and off? What have you checked?
完成的
As many times as possible sometimes for 2secomds
完成的
@roseline let's see if we can get you straight on this one. What make and model is your TV? Your complete screen turns off and on? Describe exactly what it does. What have you checked? Have you tried all different inputs?
完成的
My tv do the same cane you help me
完成的
pascal onghena what make and model? what have you tried? Describe exactly what it does.
完成的
显示更多的1条评论
添加一条评论
1个答案
Tlaleng Teetsi posted just for completion sake. Obviously people are still looking at this question. If your TV comes on and then off again this is usually related to a bad power board. Unplug your set and remove the back cover. Check the power board for any obviously damaged components like domed or leaking caps. After that, you want to use a multimeter and check the fuses on your power board for continuity and check the power supply to see if it supplies the standby voltage. To show you where and what to test will be easier if you post some pictures of your power board with your question. That way we can see hat you see. Use this guide for that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tlaleng Teetsi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,224
