跳转到主内容
惠普台式机维修指南。
349 个问题 查看全部
问题已关闭
The power comes on, but it never boots into Windows.
I have an HP All-in-One that when turned on, starts up fine. It shows the HP logo and I can access the early bios options. System diagnostics show nothing amiss.
But, after it goes through some process (while the logo is showing), the screen goes completely dark. The power button goes into a sleep mode, and if you hit a key it comes out. But no response on screen.
The hard drive seems to be perfectly operational. The fan is operational. Power brick is fine.
HP Pavilion 23 All-in-One
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
On a hunch, I reseated the connection related to the monitor. Some loose connection was tripping it up, it works fine now.
The safe mode idea was a good suggestion though.
这个答案有帮助吗?
得分 0
添加一条评论
you should try booting to safe mode.. this problem seem to be a Driver error..if didn't work you may try loading your operating system again....
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 106
