跳转到主内容
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
57 个问题 查看全部
问题已关闭
after replacing the screen, hotspot and bluetooth are week signal
after replacing the screen, hotspot and bluetooth are week signal, I would like to know where is the hardware part of the devices that manage bluetooth and the hotspot ( wifi share ) to check if it is ok, the signal is so weak that if I am using bluetooth and I walk 3mtrs the connection ends same for hotspot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
most likely you didn't connect the coaxial antenna cable properly. Disassemble your device and check connections.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 89
