跳转到主内容
加入维修社区 - 创建账户
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Won't boot, keeps flashing boot logo
So, I have a Samsung SM-T230NU. When I tried to power it on, it flashed for a split second the Samsung Galaxy Tab 4 logo and then went blank. I figured it was out of juice, so I plugged it in and let it charge for an hour or so.
When I came back, it was flashing and going dark.
I tried a different cable. As soon as power was applied, it flashed and went dark again.
Now, the boot logo is showing for an even briefer amount of time.
I am suspecting the battery or USB port. I don't have parts readily available to swap, however.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
5条评论
It may be worth adding, when I plug in the device, without touching any buttons, the screen starts flashing the Samsung Galaxy Tab 4 boot logo.
I would guess a stuck power button, but the power button travels freely.
When I unplug the tablet from the computer, the flashing stops.
完成的
BE sure your using the samsung charger. If the battery doesn't have enough juice to power up and it takes a samsung charger to recharge it when its that dead. I didn't believe it when I heard that but its true.
完成的
I had the same problem. Then I changed the charger. Problem solved.
完成的
Have 2 cables that connect to the internal charger and the screen flashes and every 3 secs. Never Had a Samsung charger It has no number or code on it The State of the battery registered green on the screen showing its value Galaxy 10.1 - 2014 Edition Can you help ???
完成的
Item above is my question John Maguire
完成的
添加一条评论
12个答案
已选择的解决方案
You can try press the power on button and the volume up button for a count of 5 and release and then press both in again. This often happens after a firmware update.
hope this helps
这个答案有帮助吗?
得分 7
13条评论:
I tried the power + volume up buttons, and the device did not respond at all.
完成的
Worked after i held it down for 15 seconds then released then pressed it in.
完成的
It worked on micromax canvas nitro a311 too.
完成的
This work well to my note 4 , thank u, I hold power button and volume up button for maybe 20-30 second.
完成的
I had to press the power + volume down + home buttons for about 5 seconds and the phone restarted and worked
完成的
显示更多的8条评论
添加一条评论
Mine did this, but plugging it into another charger seems to have resolved the problem. It appears that if the tablet is dead and plugged in, it can charge for a short time and start the boot sequence -- if the charger cannot supply enough current for the running device the boot sequence aborts and the cycle starts over again. The power & volume up combination has no effect because the boot loader is invoked and it aborts like the normal boot sequence. So, find a charger that can supply enough current, it should then boot, then shut it down to charge properly.
Caution, the tablet should never reach a usable charge while cycling on and off. I would expect prolonged cycling to dramatically reduce battery life as well.
这个答案有帮助吗?
得分 3
1条评论:
i tried doing this and it works but when i remove the charger or turn off the tablet it keeps doing the cycle again.. what should i do?..
完成的
添加一条评论
I have one right now doing the same thing - the customer thought it might be the charging port. It was a dead stick, so I put the tablet on a good Samsung 2.0amp charger and after about a day I started getting this flashing I have a battery one order and will test it out once it arrives.
这个答案有帮助吗?
得分 2
3条评论:
Update - I put the new battery in - and it would turn on, but not charge.. new charging port in going in today -
https://www.facebook.com/Freytechnology/...
完成的
Update - replacing the Charging port worked - I used my heat gun on high with a little flux to pop the old one off, just did the same in reverse to replace it.
完成的
Worked after holding the volume down and home key in case of galaxy c9pro
完成的
添加一条评论
Mine is doing the same thing.
这个答案有帮助吗?
得分 0
3条评论:
Mine keeps saying no command
完成的
Just happened to me. After update, flashing Galaxy tab A screen, could not turn off. Plugged into laptop USB 3 port and instantly finished installing update. Thanks
完成的
Me too... after plugging into laptop, it immediately started loading Wow, thanks!
完成的
添加一条评论
So is mine. Just started today. Could it be the battery?
这个答案有帮助吗?
得分 0
添加一条评论
Mine flashes the charging logo and goes blank. I've tried pushing the volume button. I've tried to push the volume button with the power button and I've tried different cables and nothing :(
这个答案有帮助吗?
得分 0
添加一条评论
You might need to try using a Samsung charger mine was like that when I used an old charger but when I used the charger that came with my Samsung Galaxy s6 edge it worked perfectly
I hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
I did everything here to no avail. Reinstalled firmware n good as new ☺
这个答案有帮助吗?
得分 0
2条评论:
well i have a A5 2016 and it started after pressng _"-"volume and Power button for 5 seconds and then re pressing the two of them again. Tha nks for the options guys!
完成的
the same happened to my A5 2016. Volume - and power saves it.
完成的
添加一条评论
Here's what's worked for me in the past. Take the back off with a credit card (carefully) then unplug the connector to the battery for 5 minutes. Re-seat the connector and attempt charging the device.
这个答案有帮助吗?
得分 0
1条评论:
With which mobile model? I have a C9 Pro that is stuck on a lightning sign inside a circle. Tried pressing home + power + button down like hard reset and it brings me to a blue screen that says 'A custom OS can cause critical problems in phone and installed applications.'... Volume up to continue, volume down to cancel. Did cancel two times - nothing happened. Frustrated.
完成的
添加一条评论
Use Turbo Charger.... it's work good.... one of my customer brings me same issue tab.... i put Turbo 2.1 Amp charger.. After Android is running 60 out of 60... Suddenly get it ON.
If no pls Call : 044-4860 7143
这个答案有帮助吗?
得分 0
2条评论:
My mobile j1 ace that i want to root but now it is start and the logo is blinking
完成的
hahahahahhahahahahaha
完成的
添加一条评论
I have a tablet that's just flashing the battery logo sign on and off. What could be the problem can anyone suggest anything?
这个答案有帮助吗?
得分 0
添加一条评论
reflash the stock rom. google it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
twjolson 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 34
过去 30 天: 131
总计 112,575
