跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
Oil Gauge is full of oil
Is the oil gauge on a fa50 supposed to be filled with oil? I took it apart and it looks right but other pics I've seen you can see the E and F and the pointer. You can't on mine because it's full of oil. It still works and the ballast is fine I'm just curious if I'm missing something on the inside of the gauge or something. Thanks all!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Mike, sounds like the seal inside the gauge has failed. Replacing the gauge should fix this.
这个答案有帮助吗?
得分 0
3条评论:
Where can you find a seal since it is the same with mine
完成的
I ordered and installed a replacement gasket but that only prevents the tank from leaking. I don't know if there is a back to the gauge with the float or what. It works still but I'd like to have it work right. I even looked at pics of a gauge on eBay and it looks like I'm not missing anything. I dont know what's going on.
完成的
Mine has done that since day one. Use better oil that is translucent. As it starts to get lower - closer to E, you can see the gauge.
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 408
