跳转到主内容
一部诺基亚品牌的Windows phone,2013年4月发布。
82 个问题 查看全部
flashing nokia lumia 520
how to flash nokia lumia 520
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 107
3条评论
my phone just went off after i failed to install a new software, i need a procedure on how to start it and install a new software.
完成的
Hello how can get facebook and messenger on my lumia 520 because I cant get them anymore always they keeps on telling me API is deprecated. Please help me because I cant go without my facebook friends and family
Thanks
完成的
Hard reset is not what the question was, flash mode was.
完成的
添加一条评论
2个答案
已选择的解决方案
Nokia Lumia 520 hard reset Windows Phone 7
1. Turn off your Lumia 520 phone.
2. Press and hold the Volume down and Camera keys.
3. Press and hold the Power key.
4. When you feel the phone vibrates, release the power key, but keep pressing the volume down and camera keys, until the phone reboots. All data will be lost!
nokia lumia 520 hard reset
Nokia Lumia 520 hard reset Windows Phone 8
1. Turn the power Off.
2. Press and hold the Volume down and connect the charger or the USB cable with PC, for about 8 seconds, you will see an exclamation mark (!) on the screen. Note: If you do not press any of the following keys, then the phone wp8 will starts boot normally.
Then press the keys in this exact order:
1. Volume up
2. Volume down
3. Power
4. Volume down
这个答案有帮助吗?
得分 35
6条评论:
My Nokia Lumia 520 can switch on but when l switch it on, it just freezes with a blue screen. How can l solve this problem?
完成的
it's too good your teaching i feel it God help you so that you discover more than these.
完成的
My Nokia is not taking charge
完成的
Please my windows phone got locked and I flashed it but when I on it they said I should input some password to turn off the reset protection or so so I need help
完成的
My window Nokia can not show any app again at all ,what should i do ??
完成的
显示更多的1条评论
添加一条评论
Hi silban mukupa,
Here is a link that shows how to recover, reset and restore your phone.
https://www.microsoft.com/en-au/mobile/s...
Hopefully this is of some help.
这个答案有帮助吗?
得分 11
2条评论:
my volume up key is not working .
is there any other way to hard reset my windows phone
完成的
yes use volume down
完成的
添加一条评论
添加你的答案
mohamedrifaiy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 68,912
