跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3363 个问题 查看全部
Got wet and battery is damage
Took the iPhone apart and took the battery out. Plastic that hold the battery to the iPhone broke and I just wanted to know if changing the battery would fix it. I left the phone opened and is still opened. Would the rest of the parts still would work?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
2个回答
已选择的解决方案
DO NOT PUT IT IN RICE! You are wasting your time doing that.
Clean the board up with a toothbrush and 99.9% isypropyl alcohol, and then rinse in a tub of isypropyl alcohol, this is a basic DIY fix, for more further cleaning, you would have to remove the logic board shields, and use an ultrasonic cleaner.
这个答案有帮助吗?
按维修分数 2
添加一条评论
Well the best thing to do when the phone gets wet is to put in a box full of rice and let it sit there for a day or two.
And could attach a picture of the damaged parts and the phone.
这个答案有帮助吗?
按维修分数 -2
评论:
Rice in a salt shaker is OK for breaking up clumps, but as a desiccant just doesn't cut it for electronics. Do some research. Here's what the Apple Community says: https://discussions.apple.com/thread/566...
添加一条评论
添加你的答案
dribrahimperez 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 72
