跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
问题已关闭
Touch screen only works when back is off...
I just bought a replacement screen and it worked for 2 days and is now unresponsive. I just found something very interesting in troubleshooting it. If I leave the back cover off, the touch screen works perfectly, if I put the cover on, the screen does not respond to touch. I have checked for damage, bad seating, areas that may be applying pressure to components, I see nothing wrong at all. I did notice a few areas of electrical contact between the back cover and the main board so maybe something is grounding out for some reason but I do not see this occurring. Anyone ever run into anything like this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I know that on these phones the back will push on the battery which will push on the back of the screen and flex it slightly. This is especially an issue if the battery is starting to bulge a little. Perhaps the slight flexing of the screen is causing a problem somehow?
这个答案有帮助吗?
得分 0
2条评论:
Well I wanted to accept that answer until I took it apart once again, now even without the back there is no response to touch. Perhaps it is a bad replacement screen. The original one was cracked pretty bad but worked perfectly, ugh. I will keep this updated as I learn more. Thanks though, it was a good idea.
完成的
To confirm, I checked the level of the battery, it is perfectly flat, no bulge yet.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 272
