跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
will power on but will not start up windows
i can power it up but all i have is a black screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
yes it only works with a external monitor.
完成的
添加一条评论
1个答案
已选择的解决方案
If you restart the computer, do you see the hp logo when you start it up?
这个答案有帮助吗?
得分 3
6条评论:
no it does not it lights up but the screen stays black
完成的
1. Unplug charger
2. take battery out
3. keep power button pressed for 30secs
4. try turning it on with battery back on
if that does not work
plug to external monitor and see if there is any image. if there is no display at all we have a hardware problem and I can help you troubleshoot. If this is the issue was it dropped recently or worked on?
完成的
yes it only works on the external monitor
完成的
This sounds like the LCD needs to be replaced unless someone has been working on it I would check the connections. It is a very easy repair and part is inexpensive. Id say a repair shop would charge you $125-$150. If you need help replacing it let me know!
完成的
mine almost starts windows loading files then not even half way get an error coe?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
raelayotte 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 625
