跳转到主内容
HP Elitebook 6930p announced in September 2008 and was one of the first generation EliteBook laptops. It was advertised as the first laptop to break the 24 hour battery life barrier.
18 个问题 查看全部
How can I use the sim slot
i saw sim slot at the back and i insert sim in side and is not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
1个答案
最有帮助的答案
First, not every 6930 has a WWAN adapter, and even those without have the SIM slot. If your 6930 came with a WWAN adapter, there is an extra sticker behind the battery, next to the main label, indicating the type of WWAN adapter installed and the IMEI number.
If you have the WWAN adapter, the rest depends on the operating system.
For most Windows versions, you either have received a driver CD; if not, look on the HP website for WWAN drivers.
Under Linux, things get a bit hacky, as the un2400 adapter requires a binary firmware blob that you would need to extract from the Windows driver, as I’m not aware of any Linux distro shipping it. Unfortunately, in my own experience, I never got it to work under Linux.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ayeni Oluwaseyi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 3,699
