跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Sim reader replacement, will not read a sim!
Hello ifixit,
I come with a question about sim reader replacements on iPhones. I just started trying to replace these, so far I've done 3 phones and none of them will recognize a sim card. They were physically damaged readers that I replaced, no water damage of any sort. When I take a multimeter to the finished product, everything ohms out the same as a perfectly working sim reader that's never been replaced. I'm getting all 4 anchors attached, as well as the 6 pins in the middle and the 2 at the back for the little spring arm. I've been using 400 degrees fahrenheit to remove the readers as well as covering unwanted areas in kapton tape. When I put the new reader on, I notice it doesn't sit down perfectly flush, but everything is connected and seems to have correct resistances. For the life of me I can't get them to read a sim though, or pick up anything! Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had this problem also. I took the phone apart to look at the reader, and the tiny solder points scared me. I had pulled the phone apart and so I just put it back together and set it aside. Then, a few days ago I tried the phone for the heck of it, and it worked. All that I can think is that one or more of the connections was loose or corroded and not making contact, and that the disassemble and reassemble corrected the contact issue... just a guess.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 170
