will not turn on after having a power outage
my workforce will not power up after a power outage.
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
这个答案有帮助吗?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 5,084
1条评论
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
由 Tyler Momberger 完成的
