跳转到主内容
The Samsung Galaxy Nexus is part of Google's NEXUS lineup of flagship devices. It has an HD Super AMOLED display, curved display, and Android version 4.0 Ice Cream Sandwich.
41 个问题 查看全部
I dropped my phone & now the screen shows black
I dropped the phone while in a rubberized case with a plastic cover, and the screen is now black. The phone still works, but I can't use it because the touch screen is unresponsive & I can't see any of the content. How can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
You may want to disassemble the phone enough to be able to check its connections on the motherboard. It is possible that the displays connection was loosened when it was dropped. Try reseating the display's cable connections and see if this fixes the problem. You may also want to look over the cables and other parts for damage.
If reseating the connections still leaves you with a black screen then may have broken the LCD in the display. To fix this would require a new LCD or new display assembly(LCD ➕ digitizer) if the digitizer is damaged too. The digitizer is the part of the display that is responsible for sensing touch. Hope this is helpful.
这个答案有帮助吗?
得分 1
1条评论:
If I wanna fix it myself how much would the LCD digitizer cost for my Samsung J2
完成的
添加一条评论
添加你的答案
Hetesh Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,782
