跳转到主内容
Production of the fifth generation 2010 Subaru Legacy began the last week of May 2009 at the Indiana location, and was unveiled at the 2009 New York Auto Show.
2 个问题 查看全部
How to added transmission oil
how to added transmission oil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
这个答案有帮助吗?
得分 3
添加一条评论
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
boris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 39
总计 17,168
