跳转到主内容
Released in 2014, identified by 11.6 inch screen, 2-in-1 convertible touchscreen laptop. Model number 11t-n000.
23 个问题 查看全部
Possible to replace the CPU or welded?
I am thinking about buying a low spec Pavillion 11 x360 and then upgrading the specs if possible. However, a welded CPU would be problematic. Could you please tell me whether or not it's welded? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
if it is or is'nt anything is possible just put your mind to it
完成的
添加一条评论
1个答案
These systems have an integrated SOC that are integrated into the systemboard as indicated by the Maintenance and Service Guide spare part numbers.
While it may be possible to remove the SOC and replace it with another, the equipment required to this may be specialized for that purpose and upgrading the board itself may be more cost-effective.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Choi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,354
