trying to jump battery lights flash and horn blows
tyring to jump battery horn blows and lights flash
It's probably your alarm system that's going off. When the battery died, the car's alarm system assumed that someone is tampering with the battery or had disconnected it in order to break into the car. Here's what you can do hook up the jumper cables. The horn will start to blow. As soon as it does, using the key fob, lock and then unlock the doors or basically whatever you usually do to shut off your alarm. once you've disabled the alarm go ahead and try to start up.
这个答案有帮助吗?
It worked like a charm. It happened once before, but so long ago I forgot how to stop it. My remote doesn't work but locking and unlocking the doors a couple of times fixed the problem.
My fob for my 2004 Lincoln Towncar also did not work. After doing a reconditioning recharge with a C-Tek Charger (24-ish hours) I connected the battery loosely which started the horn blowing again. Ran to the driver door and used the key to lock and unlock a time or two. Horn stopped. Car wouldn’t crank until I tightened the battery cable clamps. So just a little Power was enough to start the horn blowing but not enough to start the car.
Thanks for this answer. Saved me a tow and a service charge at a minimum.
thank you Richard and Rob. that worked 0n my 2003 Honda pilot. Mike
Thank you, this worked wonderfully! What do you think could have caused this?
I have a viper alarm system on my car. Tried to upgrade my horn on my van tested it worked fine as a horn but alarm sound stopped working except on my fob. Connected the old horn back and still the same issue. The alarm system works except the the van makes no sound at all. Remote start. Locks side lights flash but no sound?? Is a fuse blown?
You can also put your key in the door and lock and unlock a couple of times. Worked great!
这个答案有帮助吗?
How do you use your key to unlock the door in when it's in the ignition?
I always carry an extra key in my wallet in case I get locked out!
Another way to stop the horn from blowing, open fuse box and remove horn fuse. Connect battery , start car and reinstall fuse. Problem solved
这个答案有帮助吗?
When I was trying to remove cable of negative terminal of battery I forgot to lock car by remote then suddenly I touch negative cable to terminal of battery and looked car but it different sound but after charging battery when I first connect positive and then negative it started blowing siren..so I didn't connect negative terminal because when I m trying to connect negative terminal it started siren like as a someone trying to open door with different keys or say stealing..how can I resolve this problem?
这个答案有帮助吗?
过去 24 小时: 11
过去 7 天: 72
过去 30 天: 349
总计 193,826
4条评论
What makes headlights buzzard randomly go off only when headlights are on
由 Jason Gordon 完成的
It's on a 2001 jeep wrangler
由 Jason Gordon 完成的
Your alarm?
This happened to me in my Chev van.
When my jeep alarm goes off, the headlights flash. Wranger 2008
由 jtjohnston 完成的
Toyota Sienna 2012. Once you start to jump the vehicle or replace the battery, the horn will start honking. Just walk over with the key and unlock the vehicle. it should stop honking and reset the security system
由 Stevee Walrath 完成的
