I did open it but it was after it quit finding a network. I thought maybe I could disconnect the battery and re start it , I got the battery out nut decided to not unplug it, I put it back together and it is still in searching mode, Is checking the antenna cable difficult?
Sounds like An antenna problem with your network antenna inside the phone if you have access to a Pennelope screwdriver open it up and check your antenna plug-ins
2条评论
It may just be that the antenna cable came loose, have you done any recent repairs on your device?
由 Tyler Momberger 完成的
由 dwteal 完成的
