跳转到主内容
Made by GM. It's the eighth generation of a land yacht!
24 个问题 查看全部
Why is my bonneville leaking from the driver side?
Bonneville is leaking what I think is power steering or brake fluid. My wheel gets tough to turn corners.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You've probably broke a line from the steering rack to the power steering pump or the seal has gone in the pump . Are you hearing a whine, if so get this fixed right away before you burn out the pump. A pump is a lot more expensive than a replacement line. DON'T let your pump run out of fluid.
这个答案有帮助吗?
得分 2
1条评论:
if its brake fluid you'll be out of brakes soon so be careful
I wouldn't be driving it until its fixed either way
完成的
添加一条评论
If your finding it hard to steer than you probably need a new pump already
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
savage 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 216
