跳转到主内容
修复你的物品
维修的权力
商店
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
110 个问题 查看全部
Ear phones won't go into earphone hole
Can't get earphones in
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
评论:
This was VERY helpful....!
Not being Tec savvy at all the thought of disassembling the Ipod was daunting ....and paying someone to open it to find the problem was not appealing ......
I took your advice and used a very thin needle and] it WAS lint....Didn't look like much but it was preventing the plug from going all the way in.
You made my day.
Thank You
Linette Burton
完成的
This worked for me too! I used the end of a paperclip and did a small scraping motion and then a pull-back and sweep! And ta-da! Tiniest belly button lint came out!
完成的
I am amazed but this worked for me too. I didn't see anything at all in the hole but I used a toothpick and just scraped it back and forth and all around and %#*@ if it didn't work!!! No one is more stunned than me!!
完成的
Thanks for the advice toothpick worked a treat
完成的
添加一条评论
3个回答
已选择的解决方案
Check inside the audio jack with a flashlight. There may be a piece of lint or part of the plug from the last earphones you used stuck in there. Use a sewing needle or a very thin pair of tweezers to remove any foreign objects. If it doesn't work, the iPod will have to be disassembled and have the audio jack cleared out that way
这个答案有帮助吗?
得分 9
评论:
Thank You!!! This helped A LOT! I was freaking out cause my earphones wouldn't go in. Then I looked up an answer and I found this. So thank you!
完成的
OMG! This is sooo good! I was looking everywhere for a solution and all it said was that i had to replace the audio jack. But then I found your answer and I looked inside and there was a huge ball of lint in there! Yay, I can enjoy my music again!!!
Thanks so much!
完成的
Oh my god my ipod has been sitting in my drawer broken for like 2 years now. I just so happened to take it out, wonder if it was really lost, and stumbled upon this. It actually worked and I now have an ipod again. Thank you!!
完成的
Thank you SO much, I nearly had a heart attack trying to fix it and there were tiny particles in there. I found that lightly using a tooth pick also helps. You were so helpful.
完成的
Thanks! I had pocket lint in my iPod. Got a jewelers screw driver, pulled it out, and voila. It is working again.
完成的
显示更多的5条评论
添加一条评论
I found my IPOD Nano earplug jack had cracked.how to repair my IPOD Nano Earplug Jack cracked to no cracked in so I can hear my IPOD nano through earplug again?
这个答案有帮助吗?
得分 1
添加一条评论
I am shocked I did the same thing. I was freaking out cause I use my iPhone 6 Plus and headphones A lot. There was a piece of lent inside my headphones jack hole thing. Took a paper clip and I got it out. Thank god!!!
Didn’t wanted to go to the Apple store
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Linette Burton 将永远感激不已
浏览统计数据:
过去的24小时: 5
过去的7天: 30
过去的30天: 117
总计 15,478
