跳转到主内容
Repair and disassembly guides for Asus tablets.
428 个问题 查看全部
Asus fonepad 7 K012 touch sensitivity bad after new digitizer?
I changed my cracked digitizer on my Asus fonepad 7 K012 but the touch seems to be less sensitive , I checked the ribbons and everything but it seems to be fine , what can be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
I have nearly the same problem: the touchscreen generates random touches itself. Google says, my case can be solved by lifting the digitizer a bit higher above the LCD panel.
这个答案有帮助吗?
得分 0
1条评论:
Can you describe how you lifted the digitizer?
Thanks!
完成的
添加一条评论
how fix the asus k012 touch Solution Jumper Problem Ways
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aashique 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,165
