跳转到主内容
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
47 个问题 查看全部
Car turns over but won't start
Well I have a 1992 dx 1.5l and I'm pretty sure its my fuel pump not priming but I don't know why I changed the fuel filter, the pump, but I made a dumb decision and didn't change the filter on the pump?? Could this be the problem? Or could it be a corroded connection?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Did you check the voltage at the pump . Can you hear the pump hum when you turn the key on before you crank the engine. Have you checked for spark at the plugs and can it get air. Have you checked the fuel pressure on the rail. One last thing you might want to check is your timing belt.
这个答案有帮助吗?
得分 1
评论:
How do I check the voltage at the plugs? And some time it hums and starts and sometime there is no hum it just keeps cranking ? I changed the air filter, fuel filter, and fuel pump . and how do I check fuel pressure on the rail? Thanks for the feedback
完成的
these two links may be helpfull
完成的
添加一条评论
添加你的答案
macewhodoo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 9
总计 3,307
