跳转到主内容
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
8 个问题 查看全部
问题已关闭
Squelch has no white noise
I've got a used Cobra 29 that came with our used truck. The power comes on, but I cannot get any white noise with the squelch all the way to the left. Is that normal for these CBs? I also haven't heard anyone talking, so I'm wondering if it's working at all. Is there a way to test without another CB? Thanks, kevin
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Isn't the speaker damaged?
这个答案有帮助吗?
得分 0
1条评论:
No. Sorry. I should have mentioned that the Weather is coming in fine. Just no white noise on the squelch in CB mode.
完成的
添加一条评论
i am having this problem with my radio. i pullrd the antenna apart and cleaned the corrosion, and made sure the antenna had a clean ground. then i took the radio out and checked the connection on the cb.and found the coax is bad.because i could move it and get a little white noise... so i will be getting a new coax cable. hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,789
