跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
571 个问题 查看全部
No picture after replacing digitiser glass screen
Hi all.
I smashed the screen on my husbands iPad Air, not wanting to pay a small fortune to have it repaired I watched a YouTube vid and decided to do it myself, I did the replacement and followed all the steps but the screen is not working at all now, the iPad is on as when I plug in the charger it makes the noise that it does when you put it on charge but there is no picture or anything and I'm worried now as don't want hubby to be mad that I've paid for a replacement screen and then to still have to pay someone to fix it.
Any help and advice would be greatly appreciated!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
The first thing you should do is try rebooting the iPad by holding the home button and power button at the same time for about 10 seconds. If that doesn't work, try disconnecting the LCD and digitizer cables and then reconnecting them. Make sure they click in place fully.
If it still doesn't work, you may have broken the LCD, or it could be a backlight issue. If you shine a light on the screen and look very closely, can you faintly see any images on the screen?
这个答案有帮助吗?
得分 4
3条评论:
Hi David, thanks for your help, yes I can see the image when I shine a light so think it must be the back light thing, how do I fix that?
完成的
Like David said, try holding the power and home button down at the same time for roughly ten seconds. If nothing comes up then check the cable connections.
完成的
Most likely there is a burned out filter on the board. It requires micro soldering skills to be able to replace it, so unfortunately I would recommend sending that out to someone with the experience and tools to test and repair it properly.
I don't know what the rules are on posting links to other businesses on here, but you should google iPad Rehab, they have a good reputation.
完成的
添加一条评论
Sometimes when changing a screen if you don't disconnect the battery then it can cause a filter/fuse for the backlight to blow meaning the backlight won't work and you will have a dark screen.
Sounds like that could be your problem or could be a problem with the connector or faulty screen.
这个答案有帮助吗?
得分 0
添加一条评论
Thankyou for the HOME button and POWER combination i just repaired a damaged screen and thought i blew something or did something wrong, so your answer most helpfull indeed, will remember for the next time; if there is a next time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
samz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 702
