跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
Removing demo software on HTC One M8
I got a demo unit (HTC One M8) through work. I have tried to restore this to work as a normal phone, but I was unable to do so. There is an app called Demo that I cant uninstall. The Developer mode can't be touched but USB debugging mode is on (when I connect it to my PC). I can't do a factory reset as the OK button is greyed out.
Any tips would be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I baught one m8 with demo mode as impulse buy, didnt see this hidden in description. Demo cannot be deleted from settings as option is greyed out. I did have adb enabled though so I unlocked bootloader with HTC dev and rooted. Once custom rom was installed demo mode was gone.
这个答案有帮助吗?
得分 1
3条评论:
How do i do all this
完成的
Yes, how to do that
完成的
salamoalikom friends you can find all this in youtube just make how to unlocked bootloader and root my HTC one m8 . after ulocked and rooted you need to see an other video how to install a custom ROM in HTC one M8 thats what i do to resolve my problem .i hope that can help you . good luck.
完成的
添加一条评论
Try doing a factory reset with the phone off, turn the phone on by holding the power button and the vol - button for around 4-5 sec. this should boot the phone into bootloader mode. in the bootloader menu go to either factory reset or recovery( don't remember how it's labeled but it will be one or the other) to navigate in bootloader mode use the vol + to go up vol - to go down and the power button is select.
这个答案有帮助吗?
得分 0
3条评论:
factory reset from bootloader menu will only return to demo mode when restarted. However if adb is enabled then you can HTC unlock and root. Install custom rom and demo is gone.
完成的
How do you know if the adb is enable?
完成的
Then I would flash stock HTC one M8 firmware (that is compatible and works with the phone fine) once the bootloader is unlocked which can be done instead of installing a custom ROM.
完成的
添加一条评论
how to remove demo mode from my phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
morten skaar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 14,617
