跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
问题已关闭
Both cameras are displaing colorful lines in display.
Both rear & front cameras are displaying colorful lines. Sometime lines disappears. In short they are out of order. My set is almost new and still secured from any damage. It never droped from my hands and reseted it as well. I'm really worried about it. Please somebody guide me regarding this issue. I can show images reflecting the issue. I have also shown it to a professional but he is asking too much money and not guarranting that it will become ok. Is there any utility to repair it or guide me so that i'll repair it myself as I'm having essential knowledge of hardware.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Considered that display is not failing, restoring to factory defaults may resolve this issue. If the issue persists even after the factory restore, it may increase overtime and a display replacement is inevitable eventually.
Before restoring to the factory defaults you may consider hard resetting it. You may press the home and power button at the same time while the phone is turned on. As the pone turns off and then Apple logo shows, let go the pressing of power and home quickly. If this didn't resolve, I recommend you to attempt factory restore.
You would also like to check how much space you do have in your iPhone. If you are running out of space, prefer deleting some not needed contents.
If it is most definitely the display issue, you can have it here at fraction of the repair cost. Hope it helps.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 41
