跳转到主内容
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 个问题 查看全部
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 16
3条评论
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
完成的
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
完成的
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
完成的
添加一条评论
5个答案
最有帮助的答案
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
这个答案有帮助吗?
得分 3
2条评论:
ASUS provide zip file and when we run this command it says missing text files
完成的
can you give more detailed information ?
完成的
添加一条评论
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
这个答案有帮助吗?
得分 1
添加一条评论
Mei tablet bringt das soeben was tun
这个答案有帮助吗?
得分 0
添加一条评论
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
这个答案有帮助吗?
得分 0
添加一条评论
forgot screen pattern of phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
linda2222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 63
总计 20,560
