跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1695 个问题 查看全部
My ps4 turns on but no video or sound
I recently had a bad storm .All my stuff was off but still plugged up. The next day i find out it knocked out the video output on my tv the ps4 was connected to. I Then found out ( by hooking ps4 to another tv that works) that my ps4 no longer sends out any video signal nor sound. It will power on , solid white light stays on , but no video signal. I have tried a new hdmi cable, no luck. Tried booting ps4 in safe mode numerous times, no luck. Im now at a point i dont know what to do here. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
最有帮助的答案
There's a good chance that you either have a bad HDMI port or HDMI processing chip. There are a lot of other things that it could be (with lightning you never know!) but those are the 2 things that I would suspect first.
Unfortunately there is no good way to test these two things. You can look into the HDMI port with a flashlight to make sure there are no bent pins, but after that you'd have to take the console apart and have a look inside...even if you do that though you may not be able to tell if the HDMI chip is bad or not...it may just need to be replaced to see if it fixes it.
I hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
You will need to get the HDMI port replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Poohty T 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 11,707
