跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
217 个问题 查看全部
问题已关闭
Why won't my iPhone 1st gen charge? How do I fix it?
Every time I plug in the phone, 2 things happen.
1. The phone won't charge
2. The computer said that the USB isn't recognizable.
I need help! What do I do? And if you do, can you explain in detail how to fix it or a link on it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
When the dock connector malfunctions it stops taking charges. Up on such, the dock connector assembly replacement is the only solution. You can get a replacement part here and the replacement is fairly easy.
这个答案有帮助吗?
得分 3
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 69
