跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The HTC Evo 4G LTE is an Android smartphone developed by HTC Corporation to be released exclusively by Sprint.
21 个问题 查看全部
What makes it shut off and on?
can deleting apps make it malfuction
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
thanks mr. black BUT CAN IT BE REVERSED?
完成的
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
1个回答
最有帮助的答案
Yes it can. Also rooting your device and messing around with stuff can do that too. Changing it's resolution, etc. Lots can go wrong when you play with things. If you don't know what your deleting .... usually best to leave it alone.
这个答案有帮助吗?
得分 1
评论:
thanks mr. black, but can it be reversed
完成的
Yes you have to re-flash your rom and reinstall your Gapps (google apps). Watch a tutorial on YouTube. It's easy enough and after a couple times. You can unroot your phone too but doing a factory reset should fix everything. Just hard reset your phone first before playing with custom roms etc. Most phones by default are volume down and power button at the same time when starting to go to recovery. Might be different for your phone. Just take a look on google if that doesn't work.
完成的
添加一条评论
添加你的答案
Cynthia Yarbrough 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 79
