第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2345 Questions View all
Question Closed
Detach home button from ribbon cable
How do I detach the home button from the flex/ribbon cable?
Update
Thanks for the guide, but you se in the last image. How do I detach the button from the cable?
Add a comment
5个回答
It is depends of your device, see the tear down section and follow the instruction until the home button removed.
If you not familiar with this friendly-UI website, you can use the search box at the upper right corner, just write the device you have, and the result contains everything (repair manuals, teardowns, questions, etc).
Comments:
This is the closest guide we have for that process, but we do not have a guide for separating the home button from ribbon cable.
完成的
Oh, I'm sorry, i think he just want to detach the home button from the phone.
完成的
Is it possible though?
完成的
Possibility always exist.
But I'm no expert, Markus is.
Try asking him.
完成的
Add a comment
Hope this isn't too late but it is very much possible. Using a small flat head screw driver, I worked around and then underneath the mechanism away from the button. It's just a mild adhesive holding itself to the button.
Add a comment
Won't prying the button off the ribbon cable damage the cable? Can you add low heat to it first?
Add a comment
It's basically a sticker. Just work slowly and carefully.
Add a comment
I were mess it up when trying to detach the flex cable from the plastic home button. Now it does not work. Maybe it is broken somewhere.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,575
