How to fix power button
I need away to fix my power button on my XPERIA MIRO ST23i and I need it on video please.....
Tata mohmed, when you depress the power key it pushes a micro switch with is soldered to the logic board. If you are certain it is the switch you most likely will have to find a donor board to get it from. This will require soldering of very small pieces. So unless you have the tools and the experience, you may consider sending it off to repair. this video will give you an idea
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,681
