跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
111 个问题 查看全部
troubleshoot blinking green light
Mitsubishi WS-55859 blinking light occurred after storm. light blinks continuous
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
frank de los reyes, for blinking light symptom you should try replacing the capacitors on DM first. Download some instructions from here. The link will directly download a PDF file describing how to replace the caps. Also, check this guide Different model same issues same layout. This model series was plagued by a bad DM module that caused multiple failures on all other boards. there were also issue with the EEPROM Board failure after power outages.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
frank de los reyes 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 74
