跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Replacement screen fitted successfully. LCD Blobs/Spots
When I touch the top corners where the screen starts seems like the lcd is getting distorted patches. Same with the bottom when I touch the corners & home button.
Is this to do with fitting. I have done several before & not had any problem before. I know I have had a problem with pinching the cables. e.t.c. As I have a snug fit or is it just the quality of the replacement lcd. Glass being cheap. I have not overtightened the screws.
Any advice would be helpful. Thanks in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Poor quality, or something pushing up on it like a swollen battery or flex cable.
这个答案有帮助吗?
得分 1
4条评论:
thanks for you help. I am sure it is not the battery or the flex cables so it is just the poor quality of the replacement screen. It is weird because I bought several off the same person before, With no issues. This is where it is annoying continuity of supply.
完成的
Have you tried put extra double size tape under the top & bottom of the screen to see if it makes this problem lessen?
完成的
I am not sure what you mean, but I never add anything that wasn't there to begin with.
完成的
I just mean't replacing the double sided tape. I have taken the phone all the way apart again & it still does not make any difference. Still the same I take it is just a poor quality screen. Thanks again for your help
完成的
添加一条评论
I've seen this twice before and was resolved the first time be carefully reinstalling and the second time it turned out to be the screen.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for you help. I will take it apart again & give it a whirl. I will report back.
I have a feeling it is just a bad matrix (positioning/gluing of the lcd)
完成的
Fully rebuilt. Slowly & carefully no difference. Must be just a rubbish quality replacement :(
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 109
