跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
549 个问题 查看全部
Locating the fuse. Blades won't engage
Blades won't engage so thought it might be a fuse. Where are they located ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
Kathy Kincade, the few fuses your mower most likely has are inline fuses. It sounds more like a mechanical issues than an electrical one. most mowers use belt drives and mechanical clutches to engage the blades. Check your belts and your pulleys to make sure those are properly placed. Also, we might find more information if you let us know what model your mower is.
完成的
It's a GT 5000 craftsman 25 Kohler V Twin Pro. Checked belts and all are ok.
完成的
i have been looking for the relay and cant find that location anywhere.
完成的
same issue, fuse good, wiring fine
完成的
Hello..My Murray 16 hp 46 in cut mower motor dies when I enggage the the blades. I replaced the fuses. Belts ob right. What could it be?
完成的
添加一条评论
2个答案
已选择的解决方案
The GT5000 is a hydrostatic drive with electric PTO. Now the fuse makes sense :-)the fuse will most likely be a green or blue fuse. The holder will be under the dash area, sometimes the fuse holder will just hang on the harness under the dash area but sometimes it is clipped onto the battery tray or the side of the dash area. in almost all cases though, it will be on the right hand side of the tractor.
I would place some weight on the seat 9i.e. sandbag etc), and nothing attached to your PTO, turn the switch on, then measure voltage to the PTO. If you have no power then check for a bad fuse, faulty wiring (especially the wires going to the clutch), faulty seat switch, etc. Also make sure that all the wires are properly connected. I attached the schematic for your mower so you can do some more testing if needed.
这个答案有帮助吗?
得分 4
添加一条评论
Where did I find fuse
on a cub cadet zero turn
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Kincade 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 106
总计 39,297
