跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Phone isn't turning on
I know It'd be better a solution to go to an iPhone repair shop with that.
Before I go I'd like to ask and hear if anyone having the same issue as I do.
My iPhone is not turning on now.
When I wake up in the morning I figured out my phone's off. It happens sometime as the existing Battery having some troubles before.
It wouldn't charge till 100%.
Usually it stops charging on 70-80% on average.
And turns off sometime while it had about 30-40% charge.
So I thought that was the issue.
When I tried to turn in on the screen didn't came up, I was just hearing the sound of the empty charging bip (you know what I mean, that warning sound while your'e phone having 10-20% charge).
Then I connected it to the wall charger.
The display is still blank.
Now I'm hearing the sound of charger connecting continuously/repeatedly.
It was just annoying.
So I turned the phone off.
And till then It's not taking charge neither turn on.
I have changed the battery then (as my friend got a spare battery).
Nothing happening.
Any idea would be appreciated.
Thank You in Advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
When I changed my iPhone 4 screen I had to disconnect the battery. On reassembly I put the battery grounding clip in wrong ( a small black L shaped piece) and the iPhone did exactly as you described : black screen repeated charging noise. I may be that the battery is not connected properly. This may be different for iPhone 5, but it doesn't hurt to check.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Michael.
This helps. :)
I'll check it then.
完成的
添加一条评论
Try to hard reset. How? Press power and home button at the same time for 7 seconds. Once you see the apple logo, let both go. This should resolve if it's a congestion. If you still here the sound you mentioned, the digitizer died. Needs screen replacement. You can do it on your own if you buy all-in-one screen that ships out with the required screwdrivers. This link will help if it's iPhone 5 as shown in your question picture: http://amzn.to/1S3S1Kx
Hope it helps.
这个答案有帮助吗?
得分 0
1条评论:
Tried to hard reset several times. Didn't work.
It didn't turn on. No apple logo or nothing and no sound as well.
No Power at all.
Thanks for your suggestion by the way.
完成的
添加一条评论
添加你的答案
Muntasir Mahmud Aumio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 148
