跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
59 个问题 查看全部
engine sputtring at 8500 rpm
my 1999 r1 sputtering at 8500 rpm in all gears
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
已选择的解决方案
A high rev sputter is usually valve float caused by either bad valve springs or a lack of back pressure from the exhaust. If you have a leak in your exhaust or have changed your muffler. This could be your cause.Check the gaskets around connectors and at the head.Even a small leak can cause a lack of back pressure.And if you changed your muffler did you get the right one for the bike.Mufflers are tuned for proper back pressure so a wrong muffler is also a possible cause. Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
john 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 120
