跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
AppStore, camera and other apps had disappeared from my iPad
When I did the Jailbreak, and cydia restarted, I noticed that Cydia wasn't there anymore and also the AppStore, camera, Safari and other apps had gone missing. I tried to have them back by resetting all settings and still nothing. It has iOS 8.4 can someone please help me,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Restore it back then rejailbreak something has deleted the Apps.
Did you try the search option for them?
这个答案有帮助吗?
得分 0
6条评论:
I tried that and it doesn't work, those apps are still missing and when I jailbreaked it again the sources are empty .
完成的
So you restored it back to factory and re did the jailbreak and the source info for the apps is missing?
完成的
Yes, and still nothing happens.
完成的
When you restore to factory iOS is the app store there?
Sounds like the jailbreak is causing issues.
完成的
It appears when I put the icloud account but when the apps appear it isn't there.
完成的
显示更多的1条评论
添加一条评论
Forget all. Put your iPad in DFU mode. Restore to factory defaults. Once restore completes, DO NOT RESTORE from backup. Voila!
How to put your iPhone or iPad into DFU mode? Well, follow these simple steps sincerely:
1. Plug your iPad into your Mac or Windows PC and make sure iTunes is running.
2. Hold down both the Sleep Button (on top of your device) and the Home Button (on the front underneath the screen).
3. Keep them both held down for about 7 seconds.
4. Let go power button but keep pressing home button for next 10 seconds.
That's it. It will be in DFU mode now.
这个答案有帮助吗?
得分 0
1条评论:
I tried that but now it's stuck on the apple logo.
完成的
添加一条评论
添加你的答案
Angel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 901
